FAST install question
Old Feb 7, 2017 | 02:19 PM
Rise of the Phoenix's Avatar
Originally Posted by scotty2000ss
You're going to have to run the vent tube after the MAF. I ran into this problem on my C5Z when I went to the NW 102 DBW. I had to cut a hole on the TB coupler and add a AN fitting for the vent hose. At first I had it blocked off and put a breather on the passenger side valve cover. That was WRONG!
I don't run a MAF, and what I have going from the TB to the lid is one of those hoses from intakehoses.com. It's 4x6 if I remember right. Since it's not hard plastic, I don't think that's going to work. Jason at WARR Performance said something about putting a fitting on the hose going into the intake and attaching that hose to that fitting. Would that work? I wish I'd have just bought the TB with the vent tube.
Old Feb 7, 2017 | 03:28 PM
scotty2000ss's Avatar
Check this thread out I used. Has the fittings you'll need. I tapped them into my rubber TB hose. Haven't had an issue.
http://www.toquez06.com/fast.html
Old Feb 7, 2017 | 03:41 PM
That helps a ton. Thanks!
Old Feb 7, 2017 | 04:52 PM
Glad I could help!
