Catch Can Questions
Old Feb 7, 2017 | 09:30 AM
Rise of the Phoenix's Avatar
Default Catch Can Questions
I need a vented catch can, but not sure which one I need. I need to connect the vent hose coming off the passenger side valve cover to a catch can. My TB does not have the vent tube, which is why this is needed. Which catch can do I need?
Old Feb 7, 2017 | 11:50 AM
Chris Paveglio's Avatar
Whatever you get, get a reputable one. RXSpeedworks, Elite, Mighty Mouse. Ebay ones are worthless.
Old Feb 7, 2017 | 12:07 PM
I'll likely purchase a Mighty Mouse one. He has three different kinds. I know I need a vented one because I need fresh air going to the crank-case from the vent tube coming off the valve cover.
Old Feb 7, 2017 | 12:58 PM
JakeFusion's Avatar
Super Hulk Smash
Your TB doesn't have the tube?
I posted a pic in your other thread. So not what you need. I have a Mike Norris catch can. It's a good one for the price. But the Might Mouse one looks excellent.
Old Feb 7, 2017 | 01:31 PM
scotty2000ss's Avatar
Catch can isn't going to fix this. You need to hook that line on the PS valve cover up. See your other thread. I ran into this same problem.
Old Feb 7, 2017 | 02:15 PM
Yes, that line coming from the passenger side valve cover would normally connect to the vent tube that comes off the TB. My TB has no vent tube. Jason at WARR Performance I had three options, one of which is running a catch can with a filter. Just putting a breather filter in place of the hose sounds easiest, but no clue where I would get one:
Nathan,
There are a few options for you. You could just put a small breather filter in place of that hose, add a fitting to your intake tube between the throttle body and air filter or route it to a catch can that has a filter on it.
Old Feb 7, 2017 | 03:25 PM
Nathan,
I had the breather on the PS side valve cover and my car was down in power. Felt like it was running fine but after I hooked up the PCV like it should along with a catch can I gained HUGE. Don't go the breather route. Trust me.
Here is before and after. Before having a breather on the oil cap and passenger side VC vent blocked off.<br/>After: Hooked up PCV properly along with a catch can.
Old Feb 7, 2017 | 03:57 PM
RelentleZ's Avatar
What are you assuming caused the 24hp increase? AFR? Fuel trims different?
Old Feb 7, 2017 | 04:30 PM
BlackDuk98's Avatar
That's pretty crazy power difference. I am no longer running a pcv setup. I have tried 1 can, 2 cans, multiple routings, multiple pcv valves, multiple valley covers, all hooked up with a vented can, breathers on both covers, breather on 1 cover and all have yeilded oil coated intakes on a stock 5.7, heads / cam 5.7, and new 408.
I am now running both valve covers and valley cover to a vented catch can and blocking all tb ports. It will be interesting to see what the dyno says, but results will be off due to also upgrading heads...
Pcv and catch can setups sem to work different with all motors for some reason. Some suck no oil through, some like mine are always coated no matter what way you try.
Old Feb 7, 2017 | 04:36 PM
First pull after the changes was lean down low. We added quite a bit of fuel. No tricks lol
Edit: That's also on a dyno dynamics. I'm told it reads fairly low.
Old Feb 8, 2017 | 08:47 AM
MIGHTYMOUSE's Avatar
send me a pm if we aren't talking already.
