An LS Swap Power Steering Bracket I Designed
Old Feb 8, 2017 | 07:28 PM
CasperCasper's Avatar
Default An LS Swap Power Steering Bracket I Designed
I wasn't impressed with any of the power steering brackets out there so I designed/built my own. It is made of 3/8 aluminum and is very rigid. It uses the stock truck pump (saginaw style which works with my ps box) and car water pump. Also waterjetted my own 3/4 spacers to run the camaro pump with truck accessories. Next step alternator bracket. What do you guys think ? Mind the disgusting wire mess.
Old Feb 9, 2017 | 04:52 PM
LeftySS's Avatar
Looks good. What year camaro? My dad and i just installed a 5.3 in his 68 camaro so i understand the process you are going through. I commend your work, wish i had the expertise to fab up some of my own stuff like that. We used the holley bracket system on his which is very good quality system, however pretty expensive.
Old Feb 9, 2017 | 05:36 PM
Thanks. It fits a 1973 Camaro but realistically should fit every 70-81. I hated the stock look and wanted something that will look very symetrical when the alt. is installed.
