Intake Manifold Flow Tests: LS1, LS6, TBSS, BBK, Dorman LS2, 102 Fast LSXRT & more
#81
That test only used 3 stock intakes IIRC, maybe 4. LS1, LS6, TBSS, and I think the stock LM7, not sure. All others were aftermarket, all of which improved on the OEM manifolds, some barely. All aftermarket manifolds cost much more than the OEM ones. So yeah, the LS1 was lowest, then I think LM7, followed by LS6 and TBSS, then all aftermarket ones, again not always by much distance. So you saying the LS6 is a turd is not at all accurate, as some of the aftermarket manifolds were not improvement enough to justify the much higher prices, which makes them turds too. The LS6 holds its own quite well among the lower-end but higher-priced aftermarket manifolds.
#82
Though Hammer has done well with his set up, he is still a bit of a narrow minded know it all. If this were not true, he would have acknowledged Blackbirds success with the ported, TPIS intake. There are many parts and motors in the motorsports world that have there place and pretty much none of them shine in every situation. Hammer spends too much time in SR&K.
The following users liked this post:
Ted Kay (11-14-2019)
#83
^^^ THIS ^^^^ And thank you Codyvette!
#84
#85
#87
What happened? You took a cold chisel to an LS6 manifold and you blame the manifold for lousy results? Interesting....
#89
No I realized it was a turd years ago and just threw it in the trash where it belongs
#91
#93
#96
^^^^^yup!^^^^^
#98
Black00TA- You were right! As if a high count means anything...
Sooo...... who cares?
