Advice on ls1 5.7
I am new on LS engines .
I have an ls1 5.7 l taken of Caprice 2003 .
I have a 243 heads that is not Installed.
I have a double springs lunati.
And the cam which has alot of number 130451/13047 hr113+2 w7065-11 that I don't know what does it mean .
what else I need to get 500 whp....If possible .
As I said I am new to LS ...I need any single Advice
Welcome to the LS world! Good to have you on the forum! lS is a wonderful engine.
Hopefully the moderator will move this to internal engine and you will get a lot more replies.
500 at wheels is doable but demanding with out a power adder line nos or forced induction.
This thread has a 'recipe' for 500+ at wheels.
https://ls1tech.com/forums/generatio...heads-cam.html
Best wishes on your build! Ther is a lot of knowlege in the older threads.
The second number means it has an Xtreme Marine exhaust lobe; 235 degrees @ .050" and .359" lobe lift.
HR means it's for a hydraulic roller lifter and 113+2 means the cam is ground with a 113 LSA and 2 degrees advanced.
will read in details
will read more about it, to get the proper mill of my 243 heads,
will post a picture of the cam .....hope that will help to get info about the intake
