Intake Mainfold Swap, NEED HELP right away
Old Jun 25, 2004 | 01:16 PM
freakynipples69's Avatar
Default Intake Mainfold Swap, NEED HELP right away
I just finished putting on a ls6 intake manifold on my car and now my car is insanely loud, backfires a lot, and it's not running right. I also did !air and !egr, and fixed a few small exhaust leaks. Any idea why this is happening?
Old Jun 25, 2004 | 01:22 PM
hourang's Avatar
you forget the vacuum tube in the back?
Old Jun 25, 2004 | 01:25 PM
SidewayzOZ's Avatar
Yeap, check all the vacuum tubes and tighten the intake down a bit more. I had same exact problems and after letting it run a few minutes and fixing above said problems it now runs smooth as before.
Old Jun 25, 2004 | 01:31 PM
checked, thats not the problem. also why does my car sound like "it has open headers", as my dad describes it? I am not near the car right now, its at my dads shop but he said it's really really loud, i mean thats not a bad thing but is it suppose to be really loud after installing this?
Old Jun 25, 2004 | 01:42 PM
hourang's Avatar
sounds like you opend a few exhaust leaks, lol, you sure you capped the AIR EGR good?
Old Jun 25, 2004 | 01:44 PM
I'll tell my dad to double check, anything else that could be wrong?
Old Jun 25, 2004 | 01:54 PM
hourang's Avatar
as far as the open headers sound i dont think so, if the intake is leaking or has a vaccuum leak its a different sound. did you torque the intake down in the right pattern and right torque specs?
Old Jun 25, 2004 | 01:57 PM
He said he checked all of that, there are no vaccum leaks and bolted it on right. Hopefully he'll find what the real problem is.
Old Jun 25, 2004 | 02:07 PM
have another question, why does my car backfire like crazy? when you get on it and the RPM's are high, it sounds like a machine gun going off. theres soo much back pressure. And he says the car is insanely loud, he's gonna drive it home tonight and i'll hear it myself and but any ideas why?
Old Jun 26, 2004 | 11:47 AM
hourang's Avatar
i would think if it was that loud it would be easy to find the leak. what did you change on the exhaust besides the egr and air?
Old Jun 26, 2004 | 12:02 PM
jrp's Avatar
jrp
SN95 Director
you did install the new ls6 coolant pipes and plugs right? and also removed the small clips on the knock sensor wires?
Old Jun 26, 2004 | 12:09 PM
hourang's Avatar
umm i dont think you can even bolt that thing down at all with that stuff in their could you?
Old Jun 26, 2004 | 12:17 PM
txhorns281's Avatar
Only thing I can think of is the vacuum hose to the brake booster... When i did my swap I forgot to hook it back up and it made my car sound like open headers.... I dunno about exhaust leaks... pretty sure you didn't touch anything down there to make it just sound wide open... But like you said, you said everything's hooked up so sorry bro... good luck with it!
Old Jun 26, 2004 | 12:18 PM
txhorns281's Avatar
Definitely not.... lol
Old Jun 26, 2004 | 12:19 PM
jrp's Avatar
jrp
SN95 Director
it wont seal right but you can bolt it on. just making sure he's covered all avenue's.
Old Jun 26, 2004 | 01:10 PM
SidewayzOZ's Avatar
My car sounded like it had a cam when the brake booster wasnt connected. My misfires stopped when I fixed my vacuum leak.
Old Jun 26, 2004 | 01:22 PM
hourang's Avatar
thats what i thought too but he said he checked it, i would recheck it man, check for binding, i know when i install my friends intake that hose was binded and i had to reroute it after the intake was in. double, tripple check it.
