O2 Sensor Problems I Guess?
Old Jun 25, 2004 | 05:48 PM
waterbug1999's Avatar
Default O2 Sensor Problems I Guess?
Car sputters on the highway bad .... Went and got the code and its PO155. Says its a "02 Sensor Heater Circuit Malfunction". Also says "Bank 2, Sensor 1". What is "bank 2, sensor 1"? Thanks.
Old Jun 25, 2004 | 06:17 PM
Kev98Ta's Avatar
Bank 1= Drivers side
Bank 2= Passenger side
Sensor 1= Precat
Sensor 2= Aftercat
Hope that helps you!
Old Jun 25, 2004 | 06:21 PM
Sensor 1= Precat
Sensor 2= Aftercat
Sure does... Would that cause the car to sputter real bad? Thought it was the fuel filter. Had that changed in K.S. Missouri on my way to MN where i am now. Did it real bad last night. It will rev up fine but put it in gear and go on the highway it does it everynow and then.
Old Jun 25, 2004 | 06:26 PM
Kev98Ta's Avatar
Not sure on that one. I'd imagine it could though. Cause your cpu is probably getting messed up readings from it... So its possible.
Old Jun 26, 2004 | 01:29 AM
Onyx Z's Avatar
It will make the car misfire/sputter reeeaaaaalllllyyyy bad. I could barely even drive my car when the 02's blew.
Old Jun 27, 2004 | 02:09 AM
I guess ill have to get my other two 02's sent up from TX. Just moved up to MN for a descent job offer. I have the extra two post 02's, they should work for the front right?
Old Jun 27, 2004 | 12:18 PM
Camaro SS 2002's Avatar
I got the code p0135 a month after I installed LT's. It's the same problem as you, except the drivers side. It reset the CPU and a week later the SES light has not come back on.
Old Jun 28, 2004 | 12:43 AM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
I intermittently have been getting the 155 code for about 6 months. Should not affect performance AFAIK. Still a PITA having to reset the light, though. BTW, I've logged the O2s at cruise and at WOT and they seem to be performing normally.
 Michael S. Palmer
Old Jun 28, 2004 | 12:49 AM
P Mack's Avatar
I swapped a rear to the front, works fine.
Old Jun 29, 2004 | 07:38 AM
Do you think it could be the fuel filter? It did it last night..
