Weird Noise just started
Old Jun 25, 2004 | 09:20 PM
1BADFNZ's Avatar
Default Weird Noise just started
Ok a little background
2002 Z28 M6. 17K miles. NO PULLEY (ASP etc running stock pulley)
I noticed yesterday when shifting at low rpm in town that whenever I press the clutch pedal in I hear a squealing sound that you can hear slow down as the engine slows down. I don't know if it does it at WOT or not cause i can't hear it over my exhaust.
Any thoughts?? Clutch?? I just got a Pro 5.0 w/ LSS and I was messing around and banging a coupla hard 1-2 and 2-3 shifts chirping the tires.
Thanks.
Old Jun 26, 2004 | 06:06 AM
Z28Venom's Avatar
Check your tensioner and also your idler pulleys.
This may sound weird, but check the connection that goes from the passenger side head to the top of the throttle body. Mine was almost disconnected, and I was getting the same symptoms that you have..
Good Luck
Old Jun 26, 2004 | 08:51 AM
1BADFNZ's Avatar
I installed an AMW catch can a couple of months ago and haven't had problems with that. The tensioner is the pulley you have to take a wrench to to remove belts right?? where's the idler pulley?
Thanks
Old Jun 26, 2004 | 09:18 AM
jamnut's Avatar
Could be the throwout bearing? Could be a lot of things.
Old Jun 26, 2004 | 10:00 AM
1BADFNZ's Avatar
ugh
Old Jun 27, 2004 | 09:47 PM
1BADFNZ's Avatar
Ok I checked it tonight and it sounds like it's coming from the tensioner/pulley thing.
Is this bad??? Will it mess up anything important?? Should I take it to the dealer since it's an 02 w/ 17k miles on it??
Thanks.
Old Jun 27, 2004 | 10:40 PM
hourang's Avatar
does it do it when you take the shifter out of gear?
Old Jun 27, 2004 | 10:42 PM
1BADFNZ's Avatar
yeah i can pop the hood and go and manually operate the tb and hear it.
