2" header fit oem k-member?
Old Mar 22, 2017 | 08:52 PM
jlrz28's Avatar
10 Second Fun Car
Default 2" header fit oem k-member?
Will a 2" primary header fit an oem k-member? I called Texas speed and they said don't even try it unless you have an aftermarket k member.
Old Mar 22, 2017 | 09:05 PM
TSP didn't even give it a "maybe"! Looks like you might have your answer, though it can never hurt to get more opinions. Even so, TSP has been around long enough to know what they are talking about.
Old Mar 22, 2017 | 09:08 PM
jlrz28's Avatar
10 Second Fun Car
Just wondered if the kooks set was better engineered to clear it.
Old Mar 22, 2017 | 09:11 PM
Did you mention to TSP that it is a Kooks set? If you did, then you got a definitive answer. Enough of those setups are around for TSP to know what works or not. I don't know if TSP sells Kooks (they might), but if so, then it's a lock.
Old Mar 22, 2017 | 09:12 PM
jlrz28's Avatar
10 Second Fun Car
No sure didnt, just asked about theirs.
Old Mar 22, 2017 | 09:27 PM
SoFla01SSLookinstok's Avatar
Also what I've heard. Having a tubular k-member is wanted. Unless I'm mistaken I think I've heard of people fitting them. You have to do some cutting of the k-member.
Old Mar 22, 2017 | 10:07 PM
Jtm2085's Avatar
Yep, in one of the original tsp 2in header threads there was a guy that used them with a stock k member. He did do a decent amount of cutting though
Old Mar 23, 2017 | 12:27 AM
Tuskyz28's Avatar
So basically it's cut the factory K member or buy a aftermarket K member from MWC, BUT, UMI, etc...... ?
Old Mar 23, 2017 | 01:12 AM
tug686spd's Avatar
I did TSP 2" with stock K. Theres some trimming to be done. Passanger side is the one withe hole cut in it, doesnt need to be that big but wanted clearance. Drivers side is circled an the pinched seem just needed ground back flush. Honestly it might have been possible to dent the primary slightly for the needed clearance.
Old Mar 23, 2017 | 01:21 AM
Tuskyz28's Avatar
Is the horsepower gains over 1 7/8 headers worth the trouble ?
Old Mar 23, 2017 | 01:25 AM
tug686spd's Avatar
Question
Heres a better angle to see how much i trimmed on the passanger side. I plated the hole with 1/8" material and have 3/8" clearance to the header.
Old Mar 23, 2017 | 01:30 AM
tug686spd's Avatar
To me yes I got my sights set high. Add to the fact it was a new build and didnt have headers for this car already and it was an easy choice. With motor out it was at most a 1hr job with my bare mock up block and heads. Now im putting in a UMI k though.
Old Mar 23, 2017 | 07:00 AM
Tuskyz28's Avatar
Im interested to see how they fit with that UMI k member you mentioned.....
Old Mar 23, 2017 | 07:07 AM
jlrz28's Avatar
10 Second Fun Car
I saw my motor dyno 620 with 2" headers. I'm looking for more and have 1 7/8 on it for a few years.
Old Mar 23, 2017 | 10:56 AM
tug686spd's Avatar
If you read through the other threads the aftermarket k's arent a garaunteed fit for these headers either. Pretty sure the were 2 different k's where some grinding or denting of the primary was needed. These are really nice headers for the money that require very minimal work to make them fit, I have another set waiting to go on my daughters car when its time. Put these headers with Speed Engineerings true dualls (to get rid of gay *** dumps) and you have an exhaust to support big power without most of the drone.
On a side note. I'm pretty sure I read a post from TSP somewhere that not everybody that signed up on pre sale bought them and they're not selling as well as expected. So if you think you may want these someday you better get now because once this batch is done I dont think you'll see any more. Then that leaves you with the really nice and pricey Kooks.
Old Mar 24, 2017 | 05:20 AM
maroonls1z's Avatar
I have kooks 2" and did not have any fitment issuse but i did replace the motor mounts at the same time so it sits up as high as it is ever going to. I cant promise i wont have issues down the line
Old Mar 24, 2017 | 05:59 AM
Tuskyz28's Avatar
What k member you running ?
Old Mar 24, 2017 | 11:57 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Like posted above, it's not that it can't be done, it's just that it's not a direct fit. You will have hack up the k-member and be willing to MAKE it fit. I can't speak for kooks either way. They may have clearanced theirs around a stock K-member. I'm just not sure.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Mar 24, 2017 | 12:06 PM
This is interesting. If the Kooks 2'' fit with stock k-member I will want them. One thing is I have Spohn solid motor mounts. This lifts the motor a tad. So the thing I may worry about is if they contact the body under the car. I would only get the 3" collectors.
Old Mar 24, 2017 | 12:41 PM
Jtm2085's Avatar
You could have the tsp headers and get a kmember price of the cooks. Or at least get really close.
