What gains to expect going from old Fast intake to Fast 102mm LSXR
Moderator
Received 1,838 Likes
Tusky, 243/251 but it's only used at the track. Why would he need to shift this new motor at 7200? I think he'll make peak power way before that, it just seems to over working his motor. iMO that 4" stroke and that cam is not going to make anything up there but noise. I'm very interested to see this build completed and tuned with an MSD intake.
That's how cars with less power outrun cars with more power. By stretching their gears with RPM
I think I see what you're saying,kind of, is there not some issue with nosing way over past your engine's most usable power and losing out? There's too many variables there like transmission gear ratios and the distance between peak torque and peak hp. If they're close then what you say is easier done, (if I understand correctly what your saying) but 7200? To get back to 4800 at the next gear? That will be 8-900 rpm past for him .
Super Hulk Smash
That cam is a good profile... I had it. But it's not going to spin like crazy in a 383. The IVC is too early. You're not getting 7200 out of it. You're not getting 7200 out of it in a 346.
If you had it cut as a 234/246 114+3 it'd get there. Later IVC... and more exhaust duration would carry more uptop. This is the profile I've toyed with as a streetable 383 nitrous grind with 11.5:1 CR.
Moderator
First gear ratio is 2.66, and second gear ratio is 1.78
If I take first out to 7200, the actual torque delivered through the driveshaft is 2.66 x 340 is 904.4. On the upshift, I end up in second gear at 4800 rpm, so right at peak engine torque. So I'll use 1.78 x 417 is 742.26 actual torque delivered through the driveshaft. So, if you see, even though torque has fallen off, and I landed RIGHT AT peak torque on the engine, it was STILL advantageous to ride the RPM out way past peak. In fact, if I ride it all the way out to 7500 rpm - and torque had fallen to 300, it's STILL 800 lbs of torque vs 742 on the upshift. RPM is ALWAYS advantageous, even if it "noses over"
