Pacesetter Gasket Leak
Old Jun 26, 2004 | 12:54 PM
H b K l U n A's Avatar
Default Pacesetter Gasket Leak
I have the older version of the 01-02 LS1 pacesetters. I didnt use the stock gaskets, I went with the stock gaskets which is what alot of people on here told me to do. It has been like 8 months now installed and they leak so bad and always have. There was no install problems or anything. Is there a better gasket out there that I can go with? These has the header pipes stick out kinda on the flange if you guys know what I mean. I know the new ones dont do that. Im have a new true duals made for my car so I want to fix this first. Meaning my old True Duals over the axle are for sale.
Scott
Old Jun 26, 2004 | 01:08 PM
Tranzor's Avatar
I went with some new OEM style metal gaskets I got from Napa when I did my Pacesetter install several months ago... no leaks at all. I would try swapping out your current gaskets for some brand new metal OEM style ones to see if that does the trick for you.
Old Jun 26, 2004 | 01:21 PM
86 IROC's Avatar
That's what I needed to know! Thanks. I was debating on using the supplied gaskets or not... I think I'll just go with the stock style FEL-PRO's instead.
