I LOST 20ftlbs. And 5 hp!
The first time I removed the Macs, before I did the poly mounts I test fitted the SE headers and I got them to slide right in. For some reason after the poly mounts were installed I was fighting with them to get them in. So I removed the shaft. When I go to put the SEs back in I will attempt to do it without the shaft being removed.
I hope to get back to the dyno within a couple weeks. I the longtubes are back on so I guess we will see how this new cam does!
My personal scale
Street manners > track times > dyno numbers.
If you did your setup correctly 1 + 1 + 1 = 3. Try to lean the scale one direction or the other and the other area suffers
https://www.google.com/search?site=&...k1.-BKeZT5iEoA
Cam is in and idle clip in link. Dyno soon also...at same new era.
https://ls1tech.com/forums/generation-iii-internal-engine/1868139-new-improved-prototype-hot-cam.html
Everyone talks about how good custome spec. cams are.... Well if I was gonna do a custome spec. cam this would be it.
