Power Steering Pump?
Old Apr 13, 2017 | 09:23 PM
OutsiderZ28's Avatar
Default Power Steering Pump?
Where is the best place to get a new power steering pump for my 2000 Z28? I am on my second remanufactured pump that whines pretty danged loud.
Old Apr 13, 2017 | 10:47 PM
30thanniv's Avatar
HA
My original went bad and took out my alternator.
I went with an advanced auto one that ran for a while and took a dump. Replaced it with a warranty one from Advanced. The pully disintegrated and took that one out.
I bought two rebuilt AC delco units from Rock Auto, both bad out of the box.
I am on another Advanced Auto PS pump and running well so far.
If this one goes bad I can only see buying a turn one PS pump or a brand new AC delco for $200 WITHOUT reservoir. You will have to buy reservoir separate.
If you get an answer advise.
Old Apr 15, 2017 | 06:10 AM
OVRKILL's Avatar
Turn One Steering.....done
Old Apr 15, 2017 | 08:06 AM
steering_experts1's Avatar
Unfortunately, the F-body pump has been discontinued by the manufacturer. We are working on a replacement pump. In the mean time, we can rebuild your existing pump and, if needed, upgrade it to reduce horsepower consumption and reduce fluid temperature.
Thanks,
Junior
Old Apr 15, 2017 | 10:20 AM
Thanks,
Junior
How much money and what kind of turn around time?
Old Apr 15, 2017 | 10:25 AM
That looks to be a good option, but unfortunately they are in back order at the moment.
Old Apr 15, 2017 | 10:34 AM
The standard rebuild for your pump starts at $150, and the upgraded rebuild starts at $200. Turn around time is about a week.
Thanks,
Junior
Old Apr 15, 2017 | 10:59 AM
Thanks,
Junior
Is there a guarantee on them? I would probably go the upgraded route. What all do you do the pump?
Old Apr 16, 2017 | 07:31 AM
NC_John's Avatar
Thanks,
Junior
PM sent
Old Apr 17, 2017 | 08:28 AM
We stand behind what we do 100%. If the pump fails due to our workmanship within 30 days, we will repair/replace it no cost.
If you go with the upgrade, the pump will be upgraded to reduce horsepower consumption, reduce fluid temperatures, and we will increase the pressure of the pump to handle higher wheel loads.
Thanks,
Junior
Old Apr 17, 2017 | 08:42 AM
OwieVT's Avatar
Turn One pumps are good, but if you decide for whatever reason to not go with their pump, at least buy their billet pulley. That makes the job of replacing the pump so much easier (i.e. my car has the power steering cooler and it is a pretty tight space to work). Plus it looks cool, lol.
Old Apr 17, 2017 | 08:51 AM
Thanks,
Junior
My pump will be in its way to you today, to be upgraded. I have sent you a couple PM's.
Thanks again for you assistance.
Old Apr 17, 2017 | 10:23 AM
Is it a direct replacement that uses the same belt as stock?
Old Apr 18, 2017 | 01:32 AM
Yes, our billet aluminum pulley for the 98-02 F-body is a direct replacement for the factory pulley.
Thanks,
Junior
Old Apr 18, 2017 | 07:47 AM
Ok, go ahead and add that to my upgraded pump. The stock pulley is a pain in the butt.
Old Apr 18, 2017 | 08:35 AM
Sounds great! We will add that to it as well.
Thank you for your business!
Junior
Old Sep 25, 2020 | 04:44 AM
JJ Flores's Avatar
[QUOTE=steering_experts1;19593382]The standard rebuild for your pump starts at $150, and the upgraded rebuild starts at $200. Turn around time is about a week.
interesting can I have more info on this would like to hear details 🤔 on this product?
Thank you.
Old Sep 25, 2020 | 11:33 AM
We're happy to provide any information you need. I'd suggest you first read through the Pump Rebuilding page on our website, which outlines the different rebuild options and costs for your pump. https://turnonesteering.com/rebuildi...mp-rebuilding/
Old Sep 26, 2020 | 09:56 PM
RevGTO's Avatar
Pontiacerator
I only wish I had used Turn One's services from the beginning. My buddy's shop replaced my pump with a reman because my original was leaking. The reman leaked worse than the original. They installed another reman. That one failed after about four months. Next stop was a Cardone new unit. So far so good in terms of performance, but the thing is noisy as hell, like the pump on my M6 car gets when really hot.
I had looked at Turn One pumps, but shied away from them because they seemed to expensive for a 170k mile car. Don't repeat my mistakes. Do it once, do it right. Turn One.
