Melling oil pump
Old Apr 17, 2017 | 10:23 PM
Ridgeback08's Avatar
Default Melling oil pump
Anyone installed a Melling oil pump on their LS1? If so what color o-ring did you use? I put one on my 02 TA and used the recommended o-ring, now the damn engine is ticking again.
Old Apr 18, 2017 | 07:58 AM
conan's Avatar
Blue O ring on my LS1 F-body oil pan and pick up tube.
Black O ring on my LM7 Yukon 5.3L truck pan and pick up tube.
Old Apr 18, 2017 | 12:32 PM
Is the o-ring supposed to be put on the pickup tube, then pump and tube put together? I thought the assembly instructions said to put it on the pump side. If I damaged the ring during installation I would think it would cause issues immediately, not weeks later. Do i need to replace with the same size o-ring or one that is thicker?
Old Apr 18, 2017 | 01:00 PM
milkey57's Avatar
Just did this a month ago on my gto. Ordered a new blue o ring out it on the tube then installed the tube into the pump. No issues here warm idle 40psi
Old Apr 18, 2017 | 05:22 PM
I must have put it on the pump side instead of the tube side causing it to not seat correctly. Where did you but the replacement o-ring?
Old Apr 18, 2017 | 06:42 PM
conan's Avatar
X2
Oil up the O ring slide it on the pick up tube insert pickup tube in the oil pump as straight as possible.
What color O ring was on your original pick up tube / oil pump combo ?
Old Apr 18, 2017 | 09:17 PM
Was blue. The new pump came with black and green. I used the green one (incorrectly).
Old Apr 18, 2017 | 10:29 PM
conan's Avatar
I would pull it back down and check the O ring for problems. Either pinched or too loose. Throw a blue one in there while its all apart. The pick up tube is what determines the O ring.
