Weird all of the sudden major idle issues
Old Apr 20, 2017 | 11:02 AM
neblackshirts's Avatar
Default Weird all of the sudden major idle issues
Have a question/concern that I know some of you guys can probably solve in your sleep but I'm a slow learner here lol. Took my 01 Camaro to my fathers about 450 miles from where I live to do a total paint correction and other details so now car looks better than a new Camaro but if I could only get it to run as good as it looks.
Anyways it's on a SD only tune as nobody can get the MAF to take and now wants to almost die while idling in gear or parked. It will fall to about 450-550 at stop lights. Wasn't doing this until it went 450 miles away so I thought my father was crazy so he sent me a video. Now between Lincoln Nebraska I'm at 1,175′ elevation with high humid area, while my fathers shop is in Scottsbluff, Ne and at 3,891′ elevation no humidity and obviously much thinner air but would this have an impact drastically on my tune? Went from idling at 1000 to 500-550 and running very sluggish.
Didn't know if maybe I have an IAC issue? Maybe a fouled plug? Maybe bad gas? Maybe bad fuel regulator?
J&S Performance and Tuning out of Denver, CO suggested drilling a hole in the FAST 102 TB. It's about a six hour drive to my fathers from Lincoln and probably going to make the drive Friday alone so I can help with a few things on car and hopefully maybe get something figured out on this idle/sluggish performing issue. Yes I understand that elevations impact vehicles but am shocked by how it's running out there. Doesn't run like a car that put 470 down on a Mustang Dyno. I recently spent 650 on a tune and was surprised when I pulled up to the first stop sign leaving the shop and it was osculating badly but was told it's a big cam so that's the way it is. I have HP Tuners Pro and will take my laptop to maybe see what's up but honestly I'm no expert with computers.
Run down of car:
01 Camaro SS - 408ci
Heads - AFR Mongoose 230cc / 62cc
Injectors - 60# FAST
Intake - FAST 102MM
Throttle Body - FAST 102MM
Plugs - NGK TR55
Fuel Pump - Aeromotive Stealth 340
Block - LQ9
Cam - Comp 243/251, .623/.623, 111+1 LSA, 110 ISL
Crank - Lunati 4.00" Stroke
Pistons - JE 4.04, 12cc Dished for 11:1 compression
Rods - Lunati 6.125" H-Beam
Driveshaft - Mark Williams Accu-Bond 3 1/2" Aluminum w/ Mark Williams Yokes
Axles - Moser 30 Spline
Center - Eaton Posi
Converter - Yank 3600
Rear - 12 Bolt - 3.73 gears
Trans Cooler - B&M 24,000 with fan
Transmission - 4L60E, Built Finish Line Level 5
Also video was recorded from my mothers Iphone as I told my dad drive and enjoy the Camaro as much or as little as you want. He's a EX GM Master Technician but got out of the business around 1991 so he's admitted to me that the computer stuff is foreign lol. Throw a carb and cables minus computers and he'd be in his element.
Attached Thumbnails Weird all of the sudden major idle issues-camaro-1.jpg   Weird all of the sudden major idle issues-camaro-2.jpg   Weird all of the sudden major idle issues-camaro-3.jpg
File Type: mov
Old Apr 21, 2017 | 05:12 PM
Redbull87's Avatar
Dont know if that throttle body has an idle set screw but if it does ..before drilling a hole in it like suggested.Why not just try to slightly increase the throttle blade opening a hair more and then perform a throttle position relearn. Thats a much easier solution to try..set it maybe to idle around 650-700rpm and relearn the new throttle position.It might cure it for the higher altitude and once you get the car back..lower it down again and repeat the process.
Depending on the tune..with SD only can be picky about elevation changes but Im no expert.Ive had previous cars with sd only that would be picky about just simple rain. Though not being able to tune with maf sounds like an excuse for a lazy tuner and for what you spent on a tune...I would expect the tuner to do a driveability test which wouldve shown that hunting idle that needed addressing right away.Big cam or not shouldnt hunt like that..setting a higher idle I can see..but not hunting.Good luck..i hate idle issues lol
Old Apr 21, 2017 | 07:52 PM
joecar's Avatar
If this happened all of a sudden, then you have to disgnose whst is causing this... yes, look at the IACV, and othet things... you will need a service manual, for example look at the DTC section for your year/model at www.gearchatter.com.
