Stock or PRW SFI flexplate?
I pulled the PRW off and I'm debating if I should put the new PRW on or just throw the stock flexplate on? I checked the new PRW and it's basically dead on with the stocker DIA wise and it had a tight fit on the crank like the stocker. I just done want to do this **** again. PITA to do this with the car on stands.
I was making 525-550hp crank before the custom cams and mild ported heads. I was told to expect about 100hp from the cam and heads. So at 650 crank hp will the stocker survive or take my chances with the replacement PRW?
