Steam vent tube alternative for an LS motor
Ok, I'm building a 402 and still need just a couple of parts to complete it. Some of the parts I need are the steam tube crossovers. (I plan on running one on the back as well as the front) I just dont want to run the black offs in the rear.
Now, would this be a viable option for either one? Is the ID of these pieces roughly the same as the OE tubes? Does anyone see a problem running these instead of the stockers?
I'm debating these instead since I'm running a FAST 102 and would need to bend the steam tube anyway to clear my intake. My thought was that with these I can just use flex tubing to make it as long as I need and route the tube however i need it.
Any input is appreciated.
Thanks, yo!
http://www.ebay.com/itm/LS1-Steam-Po...08e088&vxp=mtr
Thanks, yo!
There are various truck crossover tubes... the useful ones are these:
a. crossover tube with hose pipe sticking vertically up on LHS of engine;
b. crossover tube with hose pipe sticking vertically up on RHS of engine (i.e. mirror image of a.);
[ if the hose pipes sticking vertically up interfere with intake manifold, then try the crossover tubes that have the hose pipes horizontal or curved... there are quite a few variations of Gen III/IV crossover tube ]
put a. at rear (so hose pipe is now on RHS of engine) and b. at front (hose pipe on RHS)...
a T can now connect the hose pipes (via hoses) to the 2nd port on the radiator neck.
Edit: no I don't have the part numbers, sorry.
WOW, great solutions so far. So, I see on the Kurt Urban site that you can plumb the return into the stock WP. Anyone got any pics of their set ups? And since my idea of only the coolant crossovers (front and back) is shot down since they would cancel each other out, what should I do???
Anyone got any installed pics? I've seen some in the past, but I'm looking for applications using a FAST 102.
^ Been thinking about this recently also. You may be able to get the adapters and just plumb your own system.
Not on a 102, but google wasn't finding anything for that.
IMG_7200.jpg?t=1338506685
I can take a pic of my own custom system that I built when I did my ls6 intake swap. Ill get it to you tomorrow as it is pouring rain outside right now. I had some leftover steel braided line from another project and I ordered the AN adapters for the steam pipes. The system works very well.
Can't remember where the hell this union block came from on mine. I don't have a FAST, but you could consider something similar. Run the lines in front around to the back then the single line back to the rad. Pretty clean deal.....
That's a 6 port 1/8" NPT Vacuum Manifold Block which is the same thing but lower cost.
Ok, so here's what I thought the vent tubes did.... I thought the coolant ran through the heads in a certain direction to cool the head (from one to the other in front). I thought the block offs kept the coolant circulating in each head instead of going back to the other (which seemed weird). Instead it seems that coolant flows through the head whether or not the crossover is on the back.
I wanted to put the crossover in the back so that flow would continue through the heads in a circular motion to really keep the heads cool, but I guess I have it all wrong. Right?
And does anyone have pics of water pumps with the coolant return line going back into it?
Any steam and/or air pockets will rise to the highest points (the heads).
The block coolant exit port is located lower than the head, so the steam/air pockets can't leave the heads via the block coolant exit port.
With the vents blocked off, the steam/air pockets will be trapped and will cause local overheating inside the heads.
With the vents connected to some place having a lower pressure than the rest of the cooling system (e.g. radiator top, or water pump low pressure side), the steam/air pockets are allowed to leave the heads.
