Fast 92 and ls6 valley cover fitment
Old May 27, 2017 | 02:23 PM
98znasty's Avatar
Default Fast 92 and ls6 valley cover fitment
Hey everyone. I'm just finished installing a ls6 valley cover and a fast 92 intake and after torqueing it down I noticed the aluminum block that the pcv port sticks out of is touching the bottom of the fast intake. I tried sticking my feeler gauge between them and they are definitely touching. Is this normal? Or should I take it apart and grind that block some? The only thing that might make a difference is I have .040 head gaskets. Heads only had a clean up mill. Car is a 98 camaro sbe, prc stage 2.5 243 heads.
Old May 27, 2017 | 05:30 PM
98znasty's Avatar
Anybody mind going to there car and seeing if yours is touching?
Old May 28, 2017 | 04:13 PM
98znasty's Avatar
Just to let anyone who searches this later know I ended up taking my intake off and grinding down that block quite a bit before it was clear. As of now the intake is torqued down and I have .012 clearance. I'm willing to bet most of the fast 92/ls6 valley cover setups on this forum are touching judging by the amount I removed.
Old May 30, 2017 | 03:57 PM
AAIIIC's Avatar
I didn't even think to look at that when I bolted my intake down.
Old Jun 1, 2017 | 12:34 AM
98znasty's Avatar
Hopefully it's not a big deal. I searched and couldn't find anyone mention it.
Old Jun 1, 2017 | 01:30 PM
wph351's Avatar
My fast 90 and ls6 valley played well together. I'm not sure if the fast 90 is externally the same or different from the fast 92 however.
