died, now wont start.
Old Jun 29, 2017 | 04:46 PM
RAWbones's Avatar
Default died, now wont start.
I have a 1998 Monte carlo z34 that started to misfire, then the check engine light would blink, then it died, now it wont start. I also had coolant loss with no apparant location of the leak. I replaced the upper intake manifold gasket, checked for spark, its good, and my fuel rail is getting pressure. It cranks like crazy, but wont turn over. HELP!
Old Jun 29, 2017 | 07:15 PM
If it's cranking, it's turning over. It just won't start, right? If you are losing coolant but seeing no leak, there might be a head gasket issue. Leaking coolant into a cylinder would cause a misfire too. Which engine do you have?
