Uh help
102lsxr manifold (obviously)
102mm tb
Ls6 style coolant crossover with rear caps
Map sensor extension harness
Ls2 fuel rail with spacers for ls1 height injectors
You will also need to prob grind some on your water pump to make it fit.
Youll prob also want a new oil pressure sensor, knock sensors, and harness. Good things to change and have new for the long haul.
We can get you all of that and more!
Just let me know!!
