Hooker ORY....my thoughts...
When it arrived, the box was beat up (UPS)...where the Y goes into the I was dinged...it looked D-shaped, but that was easily fixed.
Putting it on was not as easy as I thought, but after I was done, it turned out great. Everything fit really well and very tight. The drivers side pipe was close to the floor, but after some fiddling, I have about 1" of room now. I also installed a poly motor mount and have had NO banging at all.
Overall, I will give the Hooker ORY (uncoated) a B. For $165 shipped, it was the easiest and cheapest I could find....and it does fit well, look good, and my personal opinion is it sounds nice. Some people dont like rasp, and this Y is raspy, I like it...the rasp is controllable, except at WOT
The clamps they supply are ****, but other than that, it cant be beat.
if I'd based my decisions solely on just how badly you've 'bashed' these headers/Y pipe all over the boards I would have never bought them from you!
Maybe I should just get QTPs as well?
The driver's side pipe was close...real close, but with some prying and tightening, I have plenty of clearance. When you get it, take the little piece of the y and test fit it...then "massage" it before you put it all together...you may get a little better clearance that way too.
It wont just install itself, but for $165 I dont think it can be beat. Well, not my perticular y pipe anyway
btw **** clamps, i'd weld it in or buy nice stainless steal ones anyways.
Good luck with the install. safe driving!
Travis
hahahaahahh Marc dont worry.... i went 11s with these headers STOCK INTERNALS....but maybe you will still run 12s????
