Fuel pump upgrade necessary?
Old Aug 22, 2017 | 10:55 PM
HappySalesman's Avatar
Default Fuel pump upgrade necessary?
As the build for my motor is nearing completion, I wanted to make sure all my ducks are in a row so I can just drop this puppy in and go.
That being said, I wanted to know if my fuel pump required upgrading. I'm aiming for about 470-480rwhp, with the white Bosch injectors. I'd read mixed feelings on what power level the factory pump could handle, and most of these are from a few years ago.
So, with all the experience we have now, what's the consensus? And if I do need to upgrade it, what's the best route to go?
Old Aug 22, 2017 | 11:20 PM
bad_408_vert's Avatar
I want to say yes you likely do, but I'm no expert and think you 'd get more replies here:
https://ls1tech.com/forums/fueling-injection-8/
Old Aug 22, 2017 | 11:40 PM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
Honestly anything above 400rwhp is taxing the factory pump with the factory anemic wiring.
The racetronix 255lph kit with hotwire is the one and done kit for you. Itll handle quite a bit more power and give you a good setup to be sure on your tune.
99+ 255lph/hotwire bundle
Old Aug 23, 2017 | 03:33 AM
HCI2000SS's Avatar
At 480 rwhp you should most definitely upgrade
