Turbo 99 ws6 derale fans check engine light on
Old Aug 23, 2017 | 06:53 PM
tigearl12's Avatar
Default Turbo 99 ws6 derale fans check engine light on
Recent turbo build on my 99 ws6 got twin derale fans had to go with higher amp alternator and wire the fan to different relays then stock but using the green trigger wire to pcm but check engine light come on when fans come on anybody have a quick fix for this ? Any suggestions would be very appreciated. Thank you
Old Aug 24, 2017 | 06:53 PM
jrpimp00's Avatar
Whats the code being thrown?
Old Aug 25, 2017 | 10:14 AM
tigearl12's Avatar
Yes it's not reading the fans we wired to new relays and running the same green trigger wire to pcm
Old Aug 25, 2017 | 03:38 PM
nine8ss's Avatar
Pretty good question here.
Old Aug 25, 2017 | 04:20 PM
....which the OP totally ignored.
Old Aug 26, 2017 | 07:39 AM
tigearl12's Avatar
Didn't ignore don't have the code # at this time have to rescan it at my builders shop but he said not reading the fans after switching to new relays .
Old Aug 26, 2017 | 12:18 PM
jrpimp00's Avatar
Hard to help without that code. Have you tried the blue trigger wire?
Old Aug 26, 2017 | 04:19 PM
SLP IROC-Z's Avatar
Codes need to be shut off in the tune
