86 Camaro, which motor mounts?
Old Aug 24, 2017 | 10:56 PM
Yes, you need the clamshell style mounts. The clamshell mounts actually attach to the frame; The engine brackets attach to them with a long bolt. The clamshell mounts are OEM parts(though Holley sells them too) and are what cushions the engine from the frame.
Old Aug 24, 2017 | 11:18 PM
86CAMARO400HP's Avatar
just to be sure, you mean the factory motor mounts for the ls1 or can I use the truck motor mounts. picture inserted
Old Aug 24, 2017 | 11:19 PM
Old Aug 24, 2017 | 11:25 PM
The Holley site specifies which ones to use. Just follow their lead on this.
Old Aug 24, 2017 | 11:32 PM
I messed up- The rubber mounts DO go on the engine, and the brackets to the frame. Don't know where my head has gone.....
Old Aug 25, 2017 | 01:54 AM
codyvette's Avatar
LOL....old school
Old Aug 25, 2017 | 01:56 AM
codyvette's Avatar
The mounts in the picture will work great. Get poly, the rubber ones will flex too much causing header/ frame clearance issues.
Old Aug 25, 2017 | 05:41 AM
user 4737373's Avatar
The Hooker engine brackets work with 4th-gen F-body engine mounts, which is exactly what is shown in that photo.
Old Aug 25, 2017 | 05:59 AM
Originally Posted by 86CAMARO400HP
Is 71223003HKR the bracket that will hook to the torque arm?
If so, how does it attach to the transmission?
The 71223003HKR brackets adapts the crossmember to the 4L60 transmission. The crossmember has a torque arm mount that divorces the torque arm from the transmission, which is a really great feature.
You can get a lot of information be reading through the Hooker 3rd-gen F-body swap thread I created on this forum, and by downloading the instructions for each part off of the Holley website.
Old Aug 25, 2017 | 03:47 PM
Do I still need to get the bracket that bolts to the engine like the one in the picture?
Old Aug 25, 2017 | 04:13 PM
No, there is no use for those when using the Hooker engine bracket set-up. This is what the mounts will look like installed on your car...
Old Aug 25, 2017 | 04:22 PM
  #32
That's a clean setup!
Old Aug 25, 2017 | 04:27 PM
  #33
Thanks. Yeah, I think the combination of the Hooker engine brackets and transmission crossmember make a real nice mounting package for 3rd-gens and the headers and exhaust systems top it off very well.
Old Aug 25, 2017 | 05:15 PM
  #34
got it.
Old Aug 26, 2017 | 06:04 PM
  #35
Thanks for your help. Definitely will go with the k member & mounts
Old Aug 26, 2017 | 07:32 PM
  #36
Glad to help. What are you plans for an oil pan? The Holley 302-2 is drop-in compatible. If you want to use a stock 4th-gen F-body pan then you'll have to notch back of the engine K-member as some other users have done.
Old Aug 26, 2017 | 09:26 PM
  #37
Yea, I have a stock ls1 oil pan, how much of a notch is this going to be?
Old Aug 26, 2017 | 09:55 PM
  #38
I never done it myself, so I can't give a discrete amount. There is a guy over on a popular 3rd-gen forum who's done it that I can point you towards if you need more info.
