Cadillac crossover tube in the rear, problems ?
Old Sep 4, 2017 | 11:18 PM
sjsingle1's Avatar
Default Cadillac crossover tube in the rear, problems ?
using the rear crossover tube from a cadillac, GM part #12605716.....it interferes with plugging in the cam sensor wire
badly bent crossover or ???
Old Sep 4, 2017 | 11:28 PM
If that crossover came off a Gen III engine it has to be badly bent as all Gen III engines use the rear cam sensor. What year Caddy did the tube come from?
Old Sep 5, 2017 | 12:03 AM
sjsingle1's Avatar
bought the crossover new off ebay....GM
Old Sep 5, 2017 | 08:49 AM
Which year was it spec'd for?
Old Sep 5, 2017 | 03:34 PM
sjsingle1's Avatar
no idea for what yr......got it for the rear as a alternative setup to tie in the front and back crossovers
Old Sep 5, 2017 | 03:36 PM
OK, then cut the tubing and attach some hose to them and work around the sensor.
Old Sep 6, 2017 | 01:45 AM
sjsingle1's Avatar
that is thought.......
Old Sep 6, 2017 | 01:46 AM
sjsingle1's Avatar
you can see it curves down from the blocks
Old Sep 6, 2017 | 11:16 AM
nine8ss's Avatar
Just pull up on it gently until it bends out of the way.
Old Sep 8, 2017 | 10:42 AM
conan's Avatar
I had to flex my Cadillac rear tube just a little up ward to get the plug to go in the cam sensor. No problems here, just don't go crazy.
Old Sep 8, 2017 | 01:14 PM
Much ado about a low-pressure plumbing issue....
