GM Bellhousing
Old Sep 11, 2017 | 10:45 AM
seakin355's Avatar
Default GM Bellhousing
I am looking for an accurate (3 decimal place or better for machining) drawing of a GM bellhousing. Do you happen to have one I could get? Or could you give me hole and dowel locations from crank centerline?
Old Sep 11, 2017 | 11:40 AM
1FastBrick's Avatar
Here you go! https://www.theturboforums.com/threa...nsions.324451/
SBC, BBC, LSX series all use the same the Bellhousing Bolt pattern
Old Sep 11, 2017 | 12:14 PM
seakin355's Avatar
Thank you very much!!! Found this one a few times.
Does anyone have one that goes out to 3 decimal places or better?
Old Sep 11, 2017 | 12:49 PM
1FastBrick's Avatar
Really not needed. Just add a zero. I made my plates based off the exact dimensions and cut them at work. They fit better than anything I have purchased.
These dimensions work. BTW they are print out of an old GM book.
Old Sep 11, 2017 | 02:20 PM
seakin355's Avatar
Ok, thanks again!!!
