Why 6.0s are so thirsty?
We also offer a "high-lift" version with .550" lift. So, there is the "drop-in" version truck cam for guys who don't want to change valve springs from factory and we have the "high-lift" version truck cams for use with our performance replacement beehive valve springs.
http://www.cammotion.com/camshafts/t...204-212-116-4/
First thing I did when I got my truck (5.3) and it gained a solid 2-3 mpg. Now my miles per dollars is equal to running 87 and the truck is 10 times more fun.
Now some people report 12-13 mpg with the 6.0 one or two folks say 18
I have regularly gotten both with my truck, all things equal, except how I drove it. I've gotten as bad as 11 over a tank full of **** MPG i'm having fun to 25 mpg over 27 miles of flat highway with a low wind day at 60-64 mph.
The fuel mileage is super susceptible to variables. Most don't baby a 6.0 truck because it's either a performance package truck or a work truck.
I agree strongly with the comment that the 6.0 may just not be very efficient due to it's intended design. Power and MPG are highly linked to efficiency. That's why a well planned overall package good combo out performs a slapped together combo always.
Sam (AMP) street tuned mine and monitored MY truck for knock and took it at as high as it could safely go. No mail order/base/ripoff tune here.
The nets didn't help etc. I think they even found it was better with the tailgate up.
If no 1 has said this then shame on you guy's. It's 1st off a HEAVY *** truck. What does this do 1st to mpg. Next the gearing in any decent sized truck is what like 4.10. Added it's a bigger bore size which is needed for More TQ that's needed for logging things around. Gearing and weight is what can or will help a 6.0.
Young man said he seen a 4mpg difference with a 5.3 vs 6.0 that's fair. Place a 6.0 in a S10 with 3.42 or 3.08's and a OD trans what would be the MPG? It's all based on the driver's Foot and driving conditions .....hills,windy,flat etc...
I've done a Ton of driving and MPG changes ALL the time. Mess with any newer style car with MPG on a long trip and it will go from reading 22mpg to 15mpg on Cruise control depending on outdoor conditions.
All that's been mentioned MANY times. I didn't read all this thread by far, I read very little of the thread and saw it mentioned several times. Hell some of it's mentioned on this very page.
But I and many others such as you too, mentioned that the trucks that the 6.0 is usually in is not a good truck to use for comparison.
I'd like someone to chime in that has a SS or VHO that drives it for MPG. The LQ9 is higher compression and going to be more efficient. It's also a half ton.
I have 3.73 gears factory in my truck same as the above trucks and I'd like to compare mine to theirs. I have a weird truck called a spring special that has the torsion bar suspension even though it's 2wd, dual piston rear brakes, full options etc etc same as the SS truck but has a 5.3 so it would be a perfect apples to apples comparison against a ss or vho 2wd since they are the exact same outside the engine
I have one benefit though, mine is electric fan. That could be part of my MPG gain that I got during tuning. Forgot to mention that earlier and it's possible that's part of my solid 2 mpg (3?) I got after my 93 octane tune
Plus they didnt make a 6.0 with 317s that had an nnbs/90mm tb on it as far as i know.
I assumed, but never pay attention, that the gen 4 6.0 used the later intake and 90mm (87)
I have personally seen gains from the Spectre cai. I have em on all 3 of my trucks.
They are same design as afe and kn but cheaper.. Made in California. Good guys with great products.
The new trucks (hd) have a 6.0 and I was wondering what they are like. Buddy said he saw one that's direct port, I think he's wrong, I cant find anything saying there is direct port on anything but gen 5
And I've been considering the speed engineering intake and headers for my NBS (for mpg and the bump in power). They have an intake that looks just like the K&N etc spectre for $69 IIRC
The 6.0 gen4 trucks all use l92 heads. 821 castings iirc. tbss used ls2 so not applicable really. You can try to compare them but there is a bit of difference. Cam, computer, intake, tb, cyl heads, block.
Making a correlation between them isnt apples to apples.
Dont quote me on this, but i think gm didnt use flex fuel on lq4 or lq9 either. I may be wrong though, but that is splitting hairs on the fleas that are on the dogs.
