Looking for additional engine temperature sensor location
Old Oct 5, 2017 | 01:42 PM
B Gordon's Avatar
Default Looking for additional engine temperature sensor location
I currently have two temperature sensors threaded into the tapped holes in the heads of my LS1 engine.
Passenger side towards the rear and drivers side near the front.
One is for the LS1 ECU and the other is for the instrument panel idiot light.
My intention is to add an actual temperature gauge and would like information as to a good location for the sensor to get an accurate reading on the engine coolant temperature.
I either need to tee into one of the current tapped holes or (preferably) to have a third tapped hole in either the head or block.
Thanks for any help.
Old Oct 8, 2017 | 02:27 AM
07NBSChevy's Avatar
You can remove one of the brass plugs on the block and give that a shot.
Old Oct 10, 2017 | 04:20 PM
B Gordon's Avatar
Does anybody have a diagram or pictures showing the location of any tapped openings in the block that would work?
The engine is in the car and I don't see any with a quick inspection.
Old Oct 10, 2017 | 05:38 PM
Go to a junkyard and look over any LS engine for the hole you desire. It might be a lot easier.
Old Oct 10, 2017 | 06:01 PM
01ssreda4's Avatar
Couple easy options, T the coolant crossover line going from the top of the radiator to the front of the cylinder heads, another is 98 models had 3 pin sensors to run the PCM and the inside gauge? Maybe you could adapt one to work in your setup?
Old Oct 10, 2017 | 06:07 PM
^^^^^ Now that is thinking outside the BLOCK! ^^^^^
Old Oct 10, 2017 | 08:36 PM
ironmikektm525's Avatar
[QUOTE=01ssreda4;19743717]Couple easy options, T the coolant crossover line going from the top of the radiator to the front of the cylinder heads, another is 98 models had 3 pin sensors to run the PCM and the inside gauge? Maybe you could adapt one to work in your setup?[/QUOTE
https://ls1tech.com/forums/generatio...u-running.html
Check that out. Works great! Thx again 01ssreda4
