Question about HVAC vacuum line
Old Oct 9, 2017 | 01:51 AM
HappySalesman's Avatar
Default Question about HVAC vacuum line
I'm installing a Fast 102 and doing an AIR delete. I removed most of the extra vacuum lines from the t-fitting behind the intake manifold. I just read that there's a 1-way check valve in this line. I can only assume it's to stop a vacuum leak from the HVAC into the motor. Is this 100% necessary? I had removed the T entirely and just ran the existing vac line into the intake. Will I be alright with this or do I need to reinstall that T with a cap?
Old Oct 10, 2017 | 12:27 PM
Viper's Avatar
Pretty sure without that check valve heat and A/C will only come out the floor and not the vents.
Old Oct 10, 2017 | 12:35 PM
98CayenneT/A's Avatar
You talking about the vacuum line that goes from the firewall on the passenger side to the back of the intake manifold ?
Old Oct 10, 2017 | 09:00 PM
Yeah. I figured it out. From the factory that line has a T at the back of the intake that also goes to the AIR injection system. There's also a check valve on the line that goes to the AIR system to prevent a vacuum leak. That was the piece I had in my hand and was worried about. The check valve for the HVAC is part of a T as well. One end goes to the intake, another goes to the HVAC, the last goes to the vacuum canister that's in front of the passenger wheel well.
