02 sierra 6.0 disappearing coolant.
So I'm trying to track down a coolant leak
I'm wondering if it could be intake manifold? According to internet there is a problem with rear ports leaking? Other sites say there is no coolant passages in intake? I'm going to replace water pump after work , but is there something I'm missing? Thanks
I finally found it. It was sitting at work and started leaking when it cooled down. Far as I could tell, Rust got behind the water pump gasket and created a leak . It would only leak when shut down cold. Changed the water pump tonight. Now I have the hydroboost leak to deal with, and she will be 100%
