90mm TB
Old Oct 15, 2017 | 11:30 AM
smcgrath's Avatar
Default 90mm TB
I have an 03 z06 and am wanting to upgrade to a 90mm intake which would obviously require a 90mm TB. I know from reading other threads that an ls2 TB will work fine as long as you get the adapter for the electrical cable. My question is would a set up with an ls3 TB also work, still using a cable adapter because the plugs are different, because from searching ls3 TBs are much more available and cheaper to find vs an ls2 TB.
Old Oct 16, 2017 | 03:09 AM
07NBSChevy's Avatar
Use the throttle body which butterfly opens the same direction as yours. I used a LS7 90mm on mine.
