Speed engineering Y pipe with dual cutouts project
#41
Looking forward to seeing how well your changes fix the clearance issue.
Is the other pipe from Kooks or TSP? Did you purchase it new? Too bad it's not a direct fit to the SE headers. It doesn't look like it's oval shape on the driver side either? Do you have it on hand as a backup option if you decide to not go with the SE after making the adjustments?
I took the "stupid" pipe to a muffler shop today to try and get that unwanted bend out but there is not enough straight pipe on either side of that bend to keep from jacking the rest of the pipe up so Im gonna have to try and heat it and bend it. If that doesn't work I will modify the TSP pipe and use it.
#42
Yes its the TSP pipe which looks like a clone of the kooks. The driver side is actually oval its just hard to tell in pic. It gets even more oval on driver side where it makes the bend towards the merge. Notice it also bends "up" to the merge to position the merge higher up. I can tell you that its possible to adjust the merge so high it would hit the driveshaft. The TSP pipe is a very nice y pipe. Its totally a knock off of the Kooks and ARH y pipe for about 1/3 the price.
#43
Please take under car pics of everything once you get it all setup and clearance measurements. What kind of torque arm brace do you have? Are you using a long or short torque arm? Curious as to whether or not the TSP needs a brace that drops down in order to clear it. Is it 3" in and 3" out?
#44
Good to know. Are you considering doing the dual cut outs like on the modded pacesetter pipe? This way, everything after the Y merge can be used to reduce the smell and noise, and opening the dual cutouts will result in flow not being effected. Can't have this if the cutout is in the I-pipe location cause then there's no room for the cats/resonator. If quietness and fuel smell aren't a concern, then that modded TSP should tuck in nicely.
#45
I however do really like that Pacesetter y pipe you got there. That is kinda the best of both worlds.
#47
Bad *** but are you gonna use the dual 3" into single 3" y pipe though? Is there a dual 3" into a 3.5"
I like the **** out of that TSP Y pipe. If I were to ever do an F body again I wouldn't do a dual 3" into a single, but Y pipes have came a long way that's for sure.
#50
#51
Second pic will show that the pipe comes STRAIGHT off of the collector. No bend down whatsoever. Third pic will show that even with the pipe coming straight off the header that there is about 1/4" clearance from the floor of the car. Its hard to tell in the pics but the pipe is slightly oval in this area. The pipe gets much more oval after this area.
#53
I will take some pics of the ground clearance once I get the rest of the exhaust installed and get my subframe connectors welded on. Too much of a pain in the *** to get car jacked up to let it down and get it back up in the air just for pics.
This y pipe is the biggest win EVER for f bodies. Price, fit, etc.
#54
