Is this the wrong pilot bearing
Old Oct 21, 2017 | 02:14 AM
Kevin Hodgkinson's Avatar
Default Is this the wrong pilot bearing
Little bit of story. This is a 2005 5.3. the clutch kit is for a 04-06 gto. is this pilot bearing the wrong size for the 5.3?
The bearing is shedding metal as I hammer it in. Like its to big
Old Oct 21, 2017 | 09:41 PM
S10xGN's Avatar
Don't know if the bearing is right or not. If it's not fitting correctly, pull it out and run a brake cylinder hone in there before going any further.
Old Oct 22, 2017 | 11:09 AM
2ToeRacing's Avatar
Is that drivin in the crank all the way?? There really isn't a right /wrong pilot so to speak. If it fits on the input shaft and seats into the crank then its right.
Old Oct 24, 2017 | 02:33 PM
Jontall's Avatar
If you want to know something then you must post all the information. 2005 5.3 from what? There are many types of pilot bearings/bushings. What is the depth to the welch plug? Did the 5.3 have an automatic transmission?
Old Oct 26, 2017 | 09:49 AM
garys 68's Avatar
There are 2 styles of pilot bearings. The one you use will depend on the transmission you're using.
Old Oct 26, 2017 | 12:17 PM
MuhThugga's Avatar
Two different pilot bearings for LS engines:
The one you use depends upon the size of the transmission's input shaft.
