Thicker intake gaskets
Old Dec 1, 2017 | 09:21 PM
Bmac89's Avatar
Originally Posted by 98CayenneT/A
Like this.
Wow that is shaved down a lot. Let me ask you this. My motor has the back 2 steam ports blocked off. It didn’t have the line going to the front when I bought the motor. I bled the air out by cracking those open when I filled it up. Should I get some steam lines to hook it back up? I’m new to the workings of the LS engines.
Old Dec 1, 2017 | 09:31 PM
There are differences of opinion on using/not using the back two ports.
Some(me included) are of the mind that better air bubble evacuation results from using them.
Others (GM included) feel they are not needed/worth the cost (Here's where GM opted out lol).
It probably works as well either way. To me it's just more efficient to use them, as a better cooling system results, but that's just me.
Old Dec 1, 2017 | 09:32 PM
Bmac89's Avatar
Originally Posted by G Atsma
No problem man!
The causes are:
-Dirty or faulty MAF
-Vacuum leak (manifold O-ring??)
-Fuel system problem (rail, injectors, pump, regulator)
So now that we have the correct code, you know what could be it. And the manifold seal IS one possibility! Try a test where you spray WD40 around the ports to see if it does anything. Any leak will become evident.
Going to give that a try this weekend. Thanks
