LS1 Ingition Relay Issue
Old Dec 16, 2017 | 05:58 PM
Rocky Rotella's Avatar
Default LS1 Ingition Relay Issue
I have a 1999 Trans Am that’s absolutely bone stock. I’m having an issue with the ignition relay circuit and am looking for feedback.
With the ignition switch on, I have power to terminals B3 (or 30) and C3 (or 85). However, with the ignition relay installed no power is transferred to C1 (or 87). Thus I have no power to the 15A INJ 1, 15A INJ 2 or 20A Eng Sen mini fuses. The engine will crank over, but because I have no fuel or spark, it obviously will not fire.
If I remove the relay and manually jump B3 (or 30) to C1 (or 87), the fuses receive power as normal and the engine starts up and operates as it should.
My first thought was that after 98,500 miles the original ignition relay finally failed. A quick trip to the local GM dealer netted a new Delphi unit. Ignition-on power returned and it started right up as expected. All seemed great for the first few starts and with only a few minutes of run time, it failed to start up. Again, I lost power to the (2) 15A INJ and single 20A Eng Sen fuses.
Any suggestion as to what might be happening on the C1 (or 87) circuit that could be causing my condition? I have no SES light or codes that would indicate a component issue. Am I looking at a grounding issue on the injector, ignition, or engine sensor side?
Any thoughts are appreciated!
Old Dec 18, 2017 | 01:24 PM
wph351's Avatar
The problem is not on the ground side of your sensors. It sounds to me like its a problem in the trigger side of the relay. If I'm not mistaken terminal 86 is the ground side of the trigger. If you have key on 12v ign power on 85, checking for good ground on 86 is a good place to start looking.
Old Dec 18, 2017 | 01:56 PM
Thank you for the response!
I plan to try that this evening as well as measure for voltage drop on the terminals beneath the fuse block.
