Ls1 water pump pulley
I've swapped pulleys on the f body pump in order to run a mechanical fan though.
Maybe explain your setup and what you're trying to achieve, there may be a simpler way to do it.
http://store.prw-usa.com/products/wa.../gm-ls-series/
I've put a truck pulley on the f body pump so I could have a mechanical fan with the forward facing f body pump outlet. That was for truck spacing. IIRC, I measured and the truck pulley cant be pushed on far enough for f body spacing.
