Remote water pump routing?
Old Jan 10, 2018 | 08:51 AM
Buryingthesun's Avatar
Default Remote water pump routing?
I cant seem to find a definitive routing for remote water pump hose routing. I have 4 ports coming out of my engine, I need to know what ports go where. I have added a photo below of my mock up engine.
Thank you all in advance!
Old Jan 10, 2018 | 10:45 AM
Look at a stock water pump to see which are pressure and return.
Old Jan 10, 2018 | 12:02 PM
ss.slp.ls1's Avatar
I don't see a photo attached to this thread.
I did a quick google search and found this link:
http://www.pirate4x4.com/tech/billavista/Cooling/
Scroll about a a third of the way down and you will find several pictures and diagrams on the water pump routing. Hope that helps.
Old Jan 10, 2018 | 12:06 PM
Not that helpful
Helpful
Thank you
Old Jan 14, 2018 | 02:07 PM
If anyone can correct me if im wrong, What I believe from what ive read is the coolant will enter my two bottom ports and exit the motor from the two top ports.
if anyone with a remote water pump could chime in it would be greatly appreciated.
Old Jan 15, 2018 | 08:38 AM
LS1MCSS's Avatar
I found a video on you tube. The two top ports are out to radiator and the two bottom ports are in from the pump.
Old Jan 15, 2018 | 05:50 PM
thank you, link would be super for future reference.
