power steering pully ?
Old Jan 17, 2018 | 04:29 PM
Mildred Jones's Avatar
Default power steering pully ?
I am putting a LQ4 in a G body--I am using LS1 front accessiories . I need a LS1 power steering pump. I have the lq4 pump. My ? is will the pulley from the LQ4 line up right on the LS1 pump or do I need the LS1 pulley also? Thanks --Lee
Old Jan 17, 2018 | 04:32 PM
ss.slp.ls1's Avatar
To be absolutely sure I would use the LS1 pulley.
Old Jan 17, 2018 | 05:28 PM
This is correct, so that you retain the correct spacing ("middle" in this case). The LQ4 pulley is out too far from the front of the engine. It uses "truck" spacing. If you're wondering, "close" spacing is what's used on Corvettes.
Old Jan 18, 2018 | 01:02 PM
Default pully
Thank you for your reply--maybe I should have ask if the pulley will interchange and still have the correct spacing.---Lee
Old Jan 18, 2018 | 01:32 PM
The LQ4 pulley will NOT interchange as it is too far forward of the engine. Use ONLY a "middle" position (Gen 4 Camaro) crank pulley
