Engine on stand, how to wire battery to turn starter ?
Old Feb 1, 2018 | 11:06 PM
sjsingle1's Avatar
Default Engine on stand, how to wire battery to turn starter ?
I want to turn the engine over so as to prime the oiling system via the starter.....how do I wire from the battery to do this ?
Old Feb 2, 2018 | 06:45 AM
RB04Av's Avatar
Hook the battery to the starter, just like in the car. + to the big post, - to the block. Then use a screwdriver to jumper the big post and the S terminal at the same time, TOUCHING NOTHING ELSE.
Old Feb 3, 2018 | 02:34 AM
sjsingle1's Avatar
hooked up jumper cables ....neg to block....pos to starter.....the starter started to smoke....and the neg cable got real hot.....took it off fast !!!
Old Feb 3, 2018 | 06:17 AM
B52bombardier1's Avatar
Sounds like a dead shorted starter internally somewhere.
Rick
Old Feb 3, 2018 | 08:54 PM
sjsingle1's Avatar
must have been a bad connection......got it to work now.....BUT is the speed of the starter fast enough to prime it??? I am not getting any oil to come out of the pushrods
oil filter is full of oil and i made sure the pump had oil in it.....i quadruple checked the O ring on the pump IT IS GOOD
Old Feb 3, 2018 | 09:58 PM
01CamaroSSTx's Avatar
Mains and rods get its oil first then the cam, lifters and push rods. Assembled my engine with a combination of ultra slick assembly lube and a high zinc oil. Built it put in the car and prior to connecting the fuel and coils up I just turned the motor over about 4-5 times and did that twice. The plugged in the fuel relay and the connected the coils and lit the pipes. Instant oil pressure!
Old Feb 3, 2018 | 11:31 PM
sjsingle1's Avatar
FINALLY ......i had to let the starter run for about 2 min straight......but got oil out the pushrods
i also took off the oil pressure sensor and filled the hole with oil.....
Old Feb 4, 2018 | 12:36 AM
LLLosingit's Avatar
Spark plugs in or out? Motor will spin over much faster without spark plug in it.
 Michael S. Palmer
Old Feb 4, 2018 | 01:49 AM
sjsingle1's Avatar
out of course
Old Feb 4, 2018 | 01:55 PM
LLLosingit's Avatar
Originally Posted by sjsingle1
out of course
Just checkin lol
