LS6 intake cleaning?
Old Feb 4, 2018 | 08:18 AM
L33's Avatar
L33
Default LS6 intake cleaning?
I have a hot *** steam cleaner with a hose and little nozzle, would this clean a dirty intake? Or what have y'all done to clean the composite intakes?
Old Feb 4, 2018 | 02:21 PM
black sky's Avatar
Dawn dishwashing liquid does a pretty good job. I usually spray down the intake with purple power or some other degreaser first. Let it sit for while and then rinse it off. After that, I use a few different brushes with the dawn solution. A flexible brush or baby bottle brush works great for the intake runners. Rinse and let dry. Good luck.
Old Feb 6, 2018 | 05:49 AM
ecoman35's Avatar
i used engine degreaser let it sit inside of intake overnight the used a cheap toilet brush to clean it. rinse well with hose after looked like new.
Old Feb 15, 2018 | 09:04 PM
a87ss305's Avatar
Get a Rubbermaid tub big enough to fit the manifold in. Put the manifold in it and fill it with hot water and Purple Power. Zip tie your compressed air blow gun handle open and place it in the bottom of the tub under the manifold. Put the cover on and let it "boil" for several hours or until clean. Did this with my LS6 manifold and it worked excellent.
Old Feb 16, 2018 | 06:39 AM
jaxcam02's Avatar
I soaked it in a big plastic bin with hot water and dawn. then scrubbed the runners with a long skinny flexible bristle brush that i found in the toilet cleaning area of my local Lowes or Home Depot. Came out clean after a rinse.
Old Feb 16, 2018 | 07:40 PM
sjsingle1's Avatar
Originally Posted by a87ss305
Get a Rubbermaid tub big enough to fit the manifold in. Put the manifold in it and fill it with hot water and SIMPLE GREEN. Zip tie your compressed air blow gun handle open and place it in the bottom of the tub under the manifold. Put the cover on and let it "boil" for several hours or until clean. Did this with my LS6 manifold and it worked excellent.
fixed it for ya
