Wich will fail
Old Feb 19, 2018 | 12:40 PM
Badbull's Avatar
Default Wich will fail
I have a 240sx wich i just swapped an LS 4.8 i bought a P2M 340Lph fuel pump and im only running the stock fuel pressure regulator, will it fail to work due to the pump pressure? or ill be good cus im thinking on buying an aftermarket FPR... engine is completely stock btw...
Old Feb 20, 2018 | 10:35 AM
I just went through this. I put a TI450 (Walbro) in my tank and used my existing corvette style regulator/filter. I had 75 lbs at the rail. You gotta go aftermarket/adjustable regulator.
