Tbss intake
Old Mar 11, 2018 | 06:53 AM
Auzzybear's Avatar
Default Tbss intake
I’m building a 2002 lm7 5.3 is the tbss intake a good choice? Power gains? What year intake should I get?
Old Mar 11, 2018 | 10:12 AM
big hammer's Avatar
The TBSS intake is the top of the turd pile when it comes to intakes. The best Stock one. Only reason a lot of guys don’t run it is because it’s way too tall for most cars
Old Mar 16, 2018 | 10:46 AM
gagliano7's Avatar
2008 -2014 truck intake same as tbss intake. Best stock intake overall except as Hammer said doesn't fit under a lot of car hoods.
Old Mar 19, 2018 | 09:43 AM
Tayj6's Avatar
It’s a good intake, but may not be the best for a 5.3 depending on mods. It does very well on the 6.0s
Old Mar 21, 2018 | 10:42 AM
Fierro51's Avatar
what part number are you guys using
Old Mar 21, 2018 | 10:54 AM
Tayj6's Avatar
Mine says 25383922
Old Mar 21, 2018 | 10:56 AM
Fierro51's Avatar
Originally Posted by Tayj6
Mine says 25383922
this one is the 90mm 4 bolt tb correct
Old Mar 21, 2018 | 10:58 AM
Tayj6's Avatar
Yes. I have an extra one with injectors and rails I would be willing to part with.
Old Mar 21, 2018 | 10:59 AM
Fierro51's Avatar
how much
Old Mar 21, 2018 | 11:01 AM
Tayj6's Avatar
$200 including shipping. It has the flex fuel injectors in it.
Old Mar 21, 2018 | 11:04 AM
Fierro51's Avatar
not really needing the injectors or rails...
Old Mar 21, 2018 | 11:11 AM
Tayj6's Avatar
No problem. Figured I would offer. Not really worth the effort to separate it out. I’ll probably put it in the classifieds at some point.
Old Mar 21, 2018 | 11:38 AM
Fierro51's Avatar
i agree, i appreciate the offer i may still take you up on it
Old Mar 21, 2018 | 01:57 PM
Auzzybear's Avatar
what size injectors are the flex fuel
Old Mar 21, 2018 | 02:02 PM
Auzzybear's Avatar
I'm doing 243 heads a decent sized cam and pac beehive springs for .625 lift
Old Mar 21, 2018 | 02:43 PM
Tayj6's Avatar
I believe they are 35lb injectors. I’ll pull the PN when I get back home.
With those mods you will see gains with the intake vs stock, for sure. You may lose a little torque at the very bottom, but average torque will be up for sure. I like the intake on 5.3s with a cam, even more with some head work and/or exhaust. The more flow the engine supports, the bigger difference you will see with the intake over stock.
Old Mar 21, 2018 | 04:04 PM
Auzzybear's Avatar
okay cool thank you! I’m trying to get the most power I can while still keeping a tight budget
Old Mar 21, 2018 | 04:11 PM
Tayj6's Avatar
They are PN 12594512. 36 lb/hr at 58psi
Old Mar 21, 2018 | 04:29 PM
Auzzybear's Avatar
im interested in purchasing this from you
Old Mar 21, 2018 | 09:45 PM
Tayj6's Avatar
Pm sent
