ASR/Cruise activating at idle?
Old Mar 18, 2018 | 11:48 AM
ZALLDAY28's Avatar
Default ASR/Cruise activating at idle?
I recently installed a NW 92mm tb and I'm not sure if it's related but now when I turn my key to the on position I hear two clicks from the asr module. After starting the car the low Trac light comes on and the asr motor starts going nuts. Any idea what would cause this? Is a cable out of adjustment?
Old Mar 22, 2018 | 08:48 PM
ZALLDAY28's Avatar
Bump.
Old Mar 22, 2018 | 08:50 PM
Chris Paveglio's Avatar
Got a scan tool? Any other electronics not plugged in? Double check fuses?
Old Mar 22, 2018 | 08:56 PM
ZALLDAY28's Avatar
No codes. Nothing unolugged. It does it on start up then settles down. But if I blip the throttle it will do it again for about 30 seconds. Can't see how the new tb would be related but it started immediately after the install. Tried adjusting the throttle cable but didn't help
Old Mar 24, 2018 | 09:53 AM
01ssreda4's Avatar
Throw that crap in the bushes.
Old Mar 24, 2018 | 10:38 AM
ZALLDAY28's Avatar
Lol thanks. Just want to make sure there's not another issue causing a problem. My car has been the king of weird issues no one has an answer for
