What water Pump?
Old Mar 22, 2018 | 08:39 PM
Default What water Pump?
Guys I tried a search, honest. I can’t find exactly what I’m after, so hopefully you guys can help. I’m wrapping up a 6 liter swap in my nephews Silvaraydo.
It’s a gen 3 build with 823 heads, Holley 92mm sniper tb, and ls3 intake. It’s a drive by cable, obviously.
The truck water pump doesn’t work, and the car intakes don’t offer provisions for manual fan fitment. I’ve did this conversion before, but it was gen4 drive by wire, and had no problem with VVT truck pump.
I know this has been done by gobs of people. What did you guys use for a water pump and manual fan? Switching to electric fans isn’t in the cards for him financially right now...
Old Mar 23, 2018 | 07:30 AM
garys 68's Avatar
There are 2 styles of truck water pumps with a threaded snout for a fan. Earlier ones had a fitting that exited strait up, later ones exited at an angle. I've seen others clearance the angled one for the ls1 intake cable tb.
If that wont work, you can swap a truck pulley on an ls1 pump. I've done this before.
Old Mar 23, 2018 | 10:17 PM
Yeah, I’ve got both truck style pumps, and I don’t think the angled one will clear much better with the cable driven throttle body.
I’ve heard of people attempting to change their pulleys out, with little to no success. You’ve done this successfully. Can you tell me how you pulled this off? Is it as simple as using a press?
Old Mar 24, 2018 | 03:48 AM
garys 68's Avatar
I've done it 3 times, no issues. Search "garys 68" and "pulley" here, you'll find pics and instructions.
There are a few styles of 98-02 f body pumps. Some have a pressed on rear cover, some bolt on. I've only used bolt on cover pumps. Some also have a grooved snout that you might be able to use a PS pulley remover, but never got one of those.
The biggest problem is removing the F body water pump pulley. There's barely any room to get between the pulley and water pump housing. I had to notch the pulley in 3 places to get 3 jaw puller on it. I couldn't figure a good way to get it in a press either. I suspect there a jig to press it off for rebuilding. I also had to cut through the bell of the pulley and along the shaft.
To press it on, remove the truck rear water pump cover. Support the bottom of the pump shaft using a small socket. Do not support it on the impeller surface, you'll just push the shaft down on the impeller. Press on the new pulley to the distance the old pulley was on.
Old Mar 24, 2018 | 04:15 AM
garys 68's Avatar
One other thought, can you flip the 4 bolt TB upside down?
Old Mar 24, 2018 | 11:57 AM
Ok, searched a few hours this morning. I see you post in tons of water pump/accessory threads, but I don’t see pics or instructions. Having said that, can you get me a link?
Will a truck pulley work on an ls7 pump? I have a new ls7 pump in the shop, that I’d use if the shaft is long enough to hold a truck pulley.
Not sure if the tb will mount upside down, and the cables work. I’ll check that out. Thanks for your help. We may end up going electric fans, if we can’t figure something out soon. Gotta get this thing out of the shop.
Old Mar 24, 2018 | 01:26 PM
garys 68's Avatar
Post 14, let me know if you can see pics off Photoshop still.
https://ls1tech.com/forums/generatio...crate-ls3.html
another:
https://ls1tech.com/forums/conversio...mp-pulley.html
I'm guessing the LS7 pump is corvette spacing. It has a very short shaft and doubt the truck pulley would go on with the correct truck spacing alignment.
Old Mar 24, 2018 | 07:42 PM
Gotcha! Thanks for the pics. You mentioned that you made a spare pump. You sell it?
Old Mar 25, 2018 | 02:52 AM
garys 68's Avatar
Gotta keep mine as a spare. But order a new 98-02 f body LS1 pump off ebay, grab a truck pump and fan at pick and pull, then all you'll need is a 3 jaw puller, press and cutoff wheel. Saw your build thread, guessing you've got those.
Just be sure the LS1 pump has a bolt on back cover.
Btw did you notice the clearance issues with the TB/air intake, water pump outlet and the fan blade in my pics? Electrics are easier. The only reason I wanted the mechanical is that it was for a 68 C3 corvette. They have one year only, VERY small radiators and marginal cooling. I went with the mechanical because they move A LOT of air and I still added an electric with that.
With a truck, towing, etc. in the Silverado, might be worth it, but try flipping the TB first.
Old Mar 25, 2018 | 03:48 PM
Wait, what? Doesn’t the pump need to be from a 12’ish Camaro, to have the truck spacing?
Old Mar 25, 2018 | 04:33 PM
garys 68's Avatar
The 2010+ Camaro pumps are spaced for truck to clear VVT, but no threaded snout for a mechanical fan.
I know the 98-02 f body LS1 pump can have a truck pulley pressed on it for truck spacing in order to have the threaded snout for mechanical fan. That's what I used.
I have no idea if the truck pulley will press on far enough to work on the 2010 Camaro pump, but I doubt it.
Old Mar 25, 2018 | 07:24 PM
RB04Av's Avatar
In a truck, why not go the junkyard and get the electric fan, wiring, and relay assy out of about a 06 - 07 2500 or Yukon or Escalade or some such; and have your tuner include the settings for the stock fan setup for that year? I gave about $100 for all the stuff for my truck, then the added tuning cost was $0.
https://www.performancetrucks.net/fo...-chevy-484892/
Piece o cake. Drops right in like it was meant to go there. Works GREAT.
Old Mar 25, 2018 | 07:35 PM
I have to agree with this. You are spending a lot of time (time=$$$) trying to use an engine driven fan, when the above can be done, making it a more efficient truck to boot.
Old Mar 25, 2018 | 08:32 PM
I totally agree with you guys. If I can find the electric fan stuff for cheap, it’s a go. It’s my nephews money after all. He’s already a bill in, with a new waterpump he can’t return because he bolted it on when I wasn’t here.
I still need to try flipping the tb over first.
I really appreciate all the help you guys are sending my way. I’ve never messed with gen 3 cable driven stuff very much, as you can tell.
