Need Help
Old Jul 5, 2004 | 01:23 PM
2GFIREHAWK's Avatar
Default Need Help
im trying to find directions on install university.com for a longtube header install on my 2000 firehawk but i cant seem to find directions can any one help me out? or link me thanks
sean
Old Jul 6, 2004 | 12:31 AM
Z28Venom's Avatar
sean
You don't really need instructions. Just get the car as high in the air as you can. Preferably on a lift, but most have just used a couple jackstands to get the car up high enough for the headers to be installed from the bottom.
Disconnect y-pipe, cats, and stock manifolds.
To install the new LT's you may need to disconnect the steering shaft to get the drivers side header to slide in. Be sure you either reuse your stock header gaskets or go to your dealer and get a new set. The passenger side is the easiest.
Just post up if you have any issues with your install.
You can also do a search. This question has been posted quiet a few times.
Good Luck.
Old Jul 6, 2004 | 12:54 AM
mooleyz28's Avatar
Here are a few things that I have searched on a found out to be of some help...
https://ls1tech.com/forums/generation-iii-external-engine/186119-tips-header-install.html
and
http://www.cardomain.com/memberpage/243722/11
These should both help.... Tips and Install docs.
Goodluck and keep us posted!
John Melamed
Old Jul 6, 2004 | 07:35 AM
jrp's Avatar
jrp
SN95 Director
check the exhaust sticky as well.
Old Jul 7, 2004 | 01:50 AM
2GFIREHAWK's Avatar
hey guys thanks alot i got them installed. the only problem i had was with the air and egr stuff. now i got to get it tuned
