GM starter questions
Old Apr 24, 2018 | 11:08 AM
ls2 bait's Avatar
Default GM starter questions
I was planning on getting a high torque starter but not many people seem to be using them, and those that have don’t say anything good about the ones they’ve used. I have ARH long tubes and a truck starter now and I have to pull the header off to get it in/ out. I thought I read somewhere one of the trucks used a smaller starter? Any leads?? Motor is 11.7:1 FWIW.
Old Apr 25, 2018 | 07:55 PM
JimsNovaLS's Avatar
I have an 11.8:1 427 and I got the Powermaster XS series #9509 starter and it works great. Sounds good and cranks fast. It has infinitely adjustable clocking for header clearance. Engine and starter have been in for a year, nothing but good so far.
Old Apr 26, 2018 | 11:33 AM
ledesordre's Avatar
Anyone running one of these with the battery in the rear? Still get enough juice to turn it over well? Was worried about the high amp draw.
Old Apr 26, 2018 | 07:54 PM
JimsNovaLS's Avatar
My battery is trunk mounted with a parts store ground cable going to the frame and a ground strap from the frame to the engine block. I think my positive cable to the starter is 2ga. copper. The above starter works fine.
Old Apr 26, 2018 | 08:06 PM
pdxmotorhead's Avatar
Cheap rear battery relocation cable thats a nice size can be pulled off almost any BMW made after about 2000, the 750 with V10/V12 cable is huge.. Has a nice connector too. And on some they have a pyro disconnect you can wire to your fire system pull ..
