Harness Rewire
Thats what I was wondering if there was a different voltage of the sensor range or something that doesnt work in aftermarket generally ........ thats interesting about the single data single also --- makes sens for reading the funtions these daya via the OBDII port ...... just not sure which go through that mechanism and which are a direct to gauge if any these days.
What vehicle are you going into and with what engine/trans/combo other etc ?
I still need to figure out how to tie the after-market A/C system into the PCM such that the PCM will raise the idle speed when the A/C is "ON", or the compressor running. I see wire Pin 17 DK GRN/WHT A/C REQUEST SIGNAL.. Can anyone confirm if I can accomplish what I'm wanting to do in this manner?
