LQ9 Brake Booster Question
Old Jun 4, 2018 | 11:29 AM
Flynman's Avatar
Default LQ9 Brake Booster Question
I have an LSX92mm Manifold on an LQ9 550hp Texas Speed Engine and a Wilwood Hyrdoboost Brake booster setup. I would like to switch to a Vacuum boost Brake system to get rid of some of the hoses under the hood. It looks like there is a vacuum port on the back of the LSX92 manifold that I assume is for vacuum brake booster. Can anyone confirm this is for brake booster?? How will switching from the Hydroboost to Vacuum brake booster effect performance??
Thank you,
Keith R
Old Jun 4, 2018 | 03:05 PM
ss.slp.ls1's Avatar
Yes, the port on the rear of the intake manifold is for a vacuum brake booster. I don't know how it will affect performance going from hydro to vacuum brakes, however you shouldn't be accelerating while you are braking, so I imagine you won't notice a difference.
Old Jun 4, 2018 | 03:52 PM
LLLosingit's Avatar
That depends on the cam you're running, If it has plenty of vacuum at idle then you won't notice a lot of difference in braking performance.
Old Jun 10, 2018 | 08:18 AM
Flynman's Avatar
Thanks for the replies!!! Guess I will find out when I get it all back together!!!
Old Jun 11, 2018 | 03:09 PM
00pooterSS's Avatar
Most notice an improvement in braking with the hydroboost, so make sure you choose between better braking or less hoses..
