5.3 with ls3 heads??
Old Aug 30, 2018 | 08:05 PM
Crysis's Avatar
Default 5.3 with ls3 heads??
I have a short block 5.3 gen 3 I'm planning on swapping into something and have a set of ls3 heads and intake should I run these whats your guys intake
Old Aug 30, 2018 | 08:13 PM
Won't work AT ALL. LS3 heads MUST go on a block with AT LEAST 4" bore, which the 5.3L does NOT have.
Old Aug 30, 2018 | 08:43 PM
Tuskyz28's Avatar
Sell the 5.3 and go 6.0 or sell the LS3 heads and buy a set of 243s/799s.
Old Aug 31, 2018 | 05:17 PM
Crysis's Avatar
Ok what about the 6.0 and ls3 heads? or will 243s be better
Old Aug 31, 2018 | 05:27 PM
LS3 heads will work on any 6.0 engine. Depending on what your goals are, the 243/799 heads will be better for low end/midrange power, LS3's for midrange/top end. This might be overgeneralizing.
What will this engine be doing? Telling us your goals for this engine will go a long way towards any of us advising you on this build.
Old Aug 31, 2018 | 06:05 PM
Crysis's Avatar
Oh ok not to sure what Ima be doing but good to know whats pros and cons
