HCI+E85+Nitrous
Old Sep 10, 2018 | 04:34 PM
GHall8788's Avatar
Default HCI+E85+Nitrous
Good afternoon guys, I have searched threads but not found anything within the last 10 years haha. I have a heads, cam, Intake 2002 Camaro m6. It currently has 430 wheel and it’s tuned for 93 octane but I recently moved to the west coast. I need to have it retuned and am planning on going E85 instead of down to 91. I have a walboro 450 pump and 60lb injectors. Do you guys think that will be enough injector for that? I also want to do a 100 wet shot down the road, curious how you guys like the e85 and nitrous setup, and if my injectors/pump will be able to push that much fuel with nitrous. Thanks In advance.
Old Sep 10, 2018 | 04:54 PM
HCI2000SS's Avatar
That pump and injectors should be fine to hold that
Old Sep 10, 2018 | 05:18 PM
GHall8788's Avatar
even with a 100 wet shot? I’m curious what my injector cycle will be at
Old Sep 10, 2018 | 05:28 PM
HCI2000SS's Avatar
Injector duty won't be effected by a wet kit. When i ran E85 on my 450 rwhp HCI my 42's were at 90% duty
Old Sep 10, 2018 | 06:49 PM
GHall8788's Avatar
solid, any benefits or negatives of running e85 with a nitrous setup?
Old Sep 11, 2018 | 02:04 PM
SlasherVRGR's Avatar
Reading plugs is a lot harder
Old Sep 12, 2018 | 12:46 PM
brandon@nitrousoutlet's Avatar
I wouldn't say that's necessarily true. Timing is in the same place, you just read the fueling differently. When reading a gas plug, we are looking for the fuel ring at the base of the porcelain. On an E85 plug, we are looking for a turn of color on the base ring of the plug to tell us where our jetting is. This is really more a measure of heat than looking at carbon deposits on the porcelain like when you're tuning with gas. If anyone needs help with this, feel free to reach out to me.
